Order Ford 8N Parts Online
8N 12 volt alternator conversion.
Lyle Pfeifer
01-29-2000 18:39:27
Does anybody sell this conversion as a kit? Or does anybody know what is the best alternator to use in a coversion and have a wiring diagram to follow? Thanks for any help, Lyle Pfeifer
STUMP PULLER
01-30-2000 17:15:07
 Re: 8N 12 volt alternator conversion. in reply to Lyle Pfeifer, 01-29-2000 18:39:27
HERE IS ANOTHER APPROACH. IF YOUR GEN IS OK, YOU COULD SWITCH TO 12V USING YOUR PRESENT GEN. YOU CAN USE A 12 V REG AND YOUR GEN WILL PRODUCE 12 V. I BELIEVE ALSO, THAT IF YOU ARE AN EXPERIMETER YOU CAN READJUST YOUR PRESENT REGULATOR TO WORK AS A 12 VOLT REG. THE ONLY DISADVANTAGE OF THIS APPROACH IS YOU DONT GET THE MAINTENANCE FREE ALT THAT ALSO CHARGES ALOT BETTER AT LOW SPEEDS. 12V WILL TURN OVER THAT N FASTER AND ALLOW MORE VOLTAGE FOR THE IGNITION AND THUS START BETTER. I LET MY N SET FOR 2 MONTHS AND WHEN I CRANKED IT OVER. IT STARTED SO QUICK I REALLY DIDNT HEAR THE STARTER TURN OVER. ABSORB ALL OF THE POSTS AND DO YOUR THING.
Mike in NC
01-30-2000 10:14:02
Lyle:
I just finished installing a Tisco 12V Conversion Kit. It works very well. As Charlie pointed out, there is little wrong with 6V, but my generator was shot and the price on a new one was about the same as the 12V conversion kit. My old 6V battery was also about gone and I had serious doubts about the regulator - so for me it was an easy decision. The Tisco Kit is very simple to install and contains new wiring, a new resistor, the necessary brackets, a 12V replacement coil, a one wire self-exciting alternator and lousy instructions. Most of the process in replacing is fairly logical and easy to do. The N Board was a great help with making up for the instructions and providing me with the correct data on Voltage. I did replace the Ampmeter with a Volt Meter because I'm a little compulsive about this N.
Mike in NC
01-30-2000 10:18:50
 Re: Re: 8N 12 volt alternator conversion. in reply to Mike in NC, 01-30-2000 10:14:02
Lyle - Don't let my comments on the quality of the instructions in the Tisco Kit scare you off from this great kit. I have no ability with electricity and I think the instructions assume the user will have some minimal knowledge of wiring.
Mike
JMCinAZ
01-30-2000 08:21:57
Recently there was a posting in here about a catalogue where you could purchase updated brackets for a clean installation of the alternator -- from what I've seen the brackets have been an obstacle for a lot of conversions. If you can acquire them, you can buy a run of the mill GM alternator as Charlie in TX recommended and save yourself some money. However, I DO recommend purchasing anything you can from the advertisers who support and make this site possible!! Any problem you may encounter, someone on here will have the solution.
Charlie in TX
01-30-2000 08:02:53
First, the 6 volt system is a good system. The only reasons I would convert is if the cost to repair was too high or if I needed 12 volts to run an implement.
To the left, under market place, you can find links to companies that make this page possible. I have seen kits there. I believe Guiness(sp?) products or Walt's tractor sells one.
The best altinator to use is from something like a '80 Chevy PU. The link below has the schematic.
Hope this helps.
