Order Ford 9N Parts Online
9N wiring diagram
JonFritts
03-03-2006 19:53:30
Ihave a 1941 9n ford tractor with front mounted distibutor.IT is still a 6 volt system.I have two ford manuals but they seem to favor the 8n tractor.I need a simple pictorial wiring or schematic specifically for the 9n.The serial no. is 46868 .Ithink it was made in the second week of January of 1941.It has an aluminum dash and it came with atwo disc plow.any help will be appreciated.THANKS.
vtscott
03-04-2006 05:25:50
 Re: 9N wiring diagram in reply to JonFritts, 03-03-2006 19:53:30
Yet another...
third party image
Jim Sturn
08-13-2006 11:41:07
 Re: 9N wiring diagram in reply to vtscott, 03-04-2006 05:25:50
I don't suppose you know where to find a schematic for 9N with magneto?
maplehillfrm,pat
03-04-2006 06:50:55
this one is actually the one I use a lot, I just couldnt find it on my puter,I'll have it on my puter now tho hahah, I have a copy printed, have a great day.
Ron/PA
03-03-2006 23:39:21
Jon, here is a copy of the diagram that came in the 1939-1947 Owners manual instruction book. Ron
third party image
Jim Sturn
08-13-2006 11:43:27
 Re: 9N wiring diagram in reply to Ron/PA, 03-03-2006 23:39:21
We are going to try to use the diagrams posted here. We think we might be able to get it to work. If anyone does have a diagram for a magneto system though it would be appreciated.
1chano
03-03-2006 20:29:53
Pats M's diagram is ok except the lights, dont wire them throught the ignition switch others say that the ignition switch can't handle the current it will ruin the ignition switch. Other than the lights the rest looks good.
Dell (WA)
03-03-2006 23:19:34
 Re: 9N wiring diagram in reply to 1chano, 03-03-2006 20:29:53
Jon..... ...as 1chano sez about Pats simplified diagram. DON'T wire yer headlights thru yer weaksister ignition switch.
Howsomevers: some of the very early alumnium dashed 9N's had a red ignition ON pilot lite on the dash somewheres. Which obviously should be powered from the ignition switch. Understand?..... ...Dell
pat maplehillfrm
03-03-2006 20:06:57
third party image
this is a fairly simple one, I have had it on my pC for some time, but not sure where it came from , I believe it was on this board,, hope it helps, pretty straight forward,pat
