Need help on new pully
Germantown jim
02-25-2006 09:54:01
Ok after hours of being learned from this 9n the crank shaft pully is off. Destorid but off... now any sugestions where to get one? I do not the deminsions of the old one due to the gear puller, BFH.bud lite and few shots crown,an oh yell all the answers on WHY WOULD... My wife didnt buy, except Bob's it anit broke DONT _ _ C K with it. TRACTOR 3 JIM 2
Hobo,NC
02-26-2006 07:55:39
 Re: Need help on new pully in reply to Germantown jim, 02-25-2006 09:54:01
If you do go back with the aftermarket spun steel pulley use part # 192160 pulley that has four 1/4” threaded bolt holes. You then kin reuse yer OEM crank bolt. You will need to counter bore the center hole of the pulley to accept the OEM crank bolt cuzz the bolt has a bevel on the underside of the hex head. reason you have to do this izz the center hole on the replacment pulley izz smaller than OEM. I have this pulley in stock.
Kelly Jewell (KY)
02-25-2006 10:49:46
Jim, I'm running a New Old Stock on eBay item number 7593339768. As far as I know there is no aftermarket except for the Pump Drive Pulley....Kelly.
