This might be an easy one, but I'm just about driven to distraction. Had the starter on my '52 8N finally go out, which was o.k. considering its age. Replaced it, along with the solenoid, just for good measure. Got it all back together and it would crank all day but would not turn over. There was absolutely NO fire. I Put in a new coil, -no fire, a new condensor and points, -no fire, new rotor and cap, and wires, - still no-no-no fire. Finally, asked two different folks on separate occasions, and both said to check the little fibre bushing and the insulator shim that surrounds the bolt that passes coil fire through the distributor housing. $1.50 later, and everything is great! Almost. Now the tractor jumps to life on the first turn, but the second I release the starter button, it dies. I even left the button pushed down an extra few seconds and the tractor runs great, - until I finally let go of the button. I even pushed the starter button with the key "Off", and it will crank great without sounding like it will fire up, until I finally flip the key to "On" while still cranking, and then it literally jumps to life as expected. This tells me I at least got a good key ignition switch, right? I already bought enough things I didn't need that I would appreciate some help if I am overlooking something simple. I ran the wiring down and don't see any obvious breaks or shorts. The only things left that aren't new yet are probably the voltage regulator and generator, along with the starter button which seems to be doing its job alright. Just to confuse things a little more, I used to notice that whenever I turned the keyswitch to "On", that the ammeter needle would flicker a little, telling me there was juice in the battery. Not no more. Even with a fully charged battery, there is absolutely no movement of that needle, - ever. Just another potentially useless symptom. Remember, the old goat ran great before the starter gave out. Hey, maybe it needs new tires! Thanks, Bob
