Order Ford 8N Parts Online
8N Can't Get into Reverse!
Bob Persse
04-28-2001 17:46:00
Was out disking this A.M. When I got to the end of a row I turned, stopped and went to put the tractor in reverse, and the shift lever pulled up and twisted in my hand. I pushed back down on it and aligned it the way I thought it should go and put it in 2nd gear. O.K. so far but then I discovered that the only gears I could get were 2nd & 4th gear, no 1st or 3 rd or reverse. Played around and finally got 1st & 3rd but still no reverse. Any thoughts guys. Really need some help. Anything will be greatly appreciated.
Regards,
Bob Persse
Marcellus, NY
1949 8N
bj/8N/mt
04-29-2001 05:52:51
 Re: 8N Can't Get into Reverse! in reply to Bob Persse, 04-28-2001 17:46:00
If you take off the shift tower and cover the problem should be pretty obvious.
Whatever you find I suggest you fix it now since the thing may not be going all the way into gear which will result in more strain on your Mastercard in the long run
Your mileage may vary
