Jubilee starting problem
Ted
04-25-2001 06:27:43
I have replaced my 6 volt battery twice in the last year. Each time the tractor starts and does good and after a few months it starts failing to start. It never shows a positive on the amp meter while running. Does this mean my voltage regulator is the problem? Thanks in advance for your help.
bj/8N/mt
04-25-2001 09:23:38
 Re: Jubilee starting problem in reply to Ted, 04-25-2001 06:27:43
Shade tree generator check is disconnect it electrically, take off the fan belt, and put power on the generator. If it motors it will generate. I T Fo4 manual goes into greater detail on this.
Your mileage may vary
bg
04-25-2001 07:48:27
Why did you replace the battery? Was it bad? Did you have it checked for dead cells? Did you try charging it? Anyway...sounds like either the generator or voltage regulator. Check the generator for output. If you don't have a way to check it, take it to an auto parts store or starter/generator shop. They'll spin it up and test the output. Chances are you'll find the problem in the generator. They go bad more often than voltage regulators. The bearings, brushes, or windings can fail. Generators cannot produce maximum voltage and maximum amperage at the same time. The voltage regulator only works when the generator voltage tries to rise above the fully-charged battery. Sounds to me like the thing isn't charging. If it checks OK, then attack the voltage regulator. Take the cover off and examine the points and see if the spring is vibrating. Some folks can adjust the VR, but it is probably better to replace it.
ED
04-25-2001 06:41:33
Claus recently set me straight on a 2N issue, I am not sure it applies to your jubilee, but here it goes.
I had installed my cutout relay backwards so the battery was draining by trying to turn the generator.
Not sure that this helped but Good Luck
