Lift Cover Bushing Removal
John.UT
04-24-2001 22:14:21
I finally got the lift arms and rocker off the hydraulic shaft (actually a friend with a torch and a press did it). One of the bushings came off in the process, but the other is stuck. Any advice on how to get a stuck bushing out of the lift housing? I have 2 new brass replacements ready to intall.
Thanks
bg
04-24-2001 23:05:54
 Re: Lift Cover Bushing Removal in reply to John.UT, 04-24-2001 22:14:21
You can press it out with a hydraulic press, or beat it out. I used a brass drift to knock mine out last week. If the one that came out easily won't get stuck, use it to drive the other one partially out.
