Order Ford 9N Parts Online
9n points
Terry
04-23-2001 14:48:02
I have been having a problem going thru points, it's not burning them the lifter on the points has worn off each set but the points are still good. I have tried different brands with the same result, I have taken the dist. apart and completely cleaned it the bushing are worn some but not a lot. Also when this happens the tang on the rotor gets burnt off. Are you not suppose to lube the cam with point lube? Any help please.
Claus
04-23-2001 15:56:12
 Re: 9n points in reply to Terry, 04-23-2001 14:48:02
Three things could cause excessive rubbing block wear. 1. Excessive point spring tension.. I rule this out, since you used different brands. 2. Lack of lubricant on the cam. I think you said that you use it.. 3. rough surface on the point cam.. Take a look at it. It should be a posished surface. As the rubbing block wears, it will lenghten your dwell angle. This would make the coil run hotter but not "burn out" the tang on the rotor. You said that you had play in the bushings. Check the gap at all four lobes while you put side pressure on the top of the dist. shaft. It should not vary more than about .001". Cam lube should be a light coat...
Happy Motoring
Claus
Terry
04-23-2001 17:07:31
 Re: Re: 9n points in reply to Claus, 04-23-2001 15:56:12
My lobes are not polished, it looks like someone used sandpaper on it too clean it up. should I try to polish or just replace the shaft? As far as the wear on the bushings goes it's not more than .001.
ZANE
04-23-2001 17:21:44
 Re: Re: Re: 9n points in reply to Terry, 04-23-2001 17:07:31
If someone has used sandpaper on the cam that could very well be the problem with wearing out the rubbing block of the points.
I would also make sure that you have not got too much voltage going to the coil. If it has been converted to 12 volts it will have to have two ballast resistors in seried in the ignition wire circuit between the ignition switch and the coil.
Also try to find a set of points that are not made of plastic. The old bakelite ones will stand much more abuse than the plastic ones and heat will not affect it either.
Terry
04-23-2001 18:38:41
 Re: Re: Re: Re: 9n points in reply to ZANE, 04-23-2001 17:21:44
When you measure the volts to the coil you do it with out the tractor running? If this is correct then I have the correct voltage as it is 4.5 volts. Terry
ZANE
04-23-2001 19:13:41
 Re: Re: Re: Re: Re: 9n points in reply to Terry, 04-23-2001 18:38:41
You might check the archives but I think the voltage should be about 3.5 volts with the engine off and the ignition on with the points closed.
What about it Claus?
Dell (WA)
04-23-2001 19:24:44
 Re: Re: Re: Re: Re: Re: 9n points in reply to ZANE, 04-23-2001 19:13:41
for an OEM 6 volt frontmount ignition coil, you want to read about 3.5 volts (2.5 min, 4.0 max) at the coil terminal WITHOUT the motor running and with the points closed. If points are open, you'll read battery volts.
There are a bunch of technical reasons that you don't want the engine running, has to do with the meter guts.
If'n you really are reading 4.5 volts without the engine running, best be to finding out why because that will overheat both your ignition points and your ignition coil and muck-up your sparkies..... ..Dell
Terry
04-24-2001 16:03:38
 Re: Re: Re: Re: Re: Re: Re: 9n points in reply to Dell (WA), 04-23-2001 19:24:44
Dell, I brought home a digital volt meter tonight and the reading I got was 3.65 which is good from what your saying. I have a double ballast resistor on there and the terminals that it was hooked up to was only putting out 1.54 volts which explains way it was hard to start, it's a wonder it even ran, shows these old tractors just won't quit. Still don't understand way the rotor tang gets burnt off, any idea? thanks for all your help guys. Terry
Al English
04-23-2001 18:14:38
The finish on the cam should not be coarser than can be done with DULL 600grit wet-or-dry sandpaper. To insure it is finished evenly and well, I would remove the cam before trying to polish it. Good luck...Al English
