block heater dimention
jimmyjack
11-28-2005 16:42:37
Anybody know offhand what the frost plug size is, I want to install a block heater.
Dell (WA)
11-28-2005 19:10:47
 Re: block heater dimention in reply to jimmyjack, 11-28-2005 16:42:37
Jimmy..... ...the domed "Welch" coreplug is listed in my N-Ford MPC as 1-3/16". UNFORTUNATELY, there is NO ROOM for the heating element of a block heater inside the block.
Recommend you seriously consider magnetic block heater for the castiron oilpan and the castiron intake manifold. You can also gitt heater pad for yer cold battery. Warm batterys really output; its a chemical reaction thing. Don't even think about a heated oil dipstick. I don't like radiator hose heaters because most of the heat excapes backout the radiator.
Iff'n yer cold, wear zipp-upp insulated coveralls or snowmobile suits..... ...Dell
Duner Wi
11-28-2005 20:03:17
 Re: block heater dimention in reply to Dell (WA), 11-28-2005 19:10:47
I have good luck with a head bolt heater in my 9N. Not sure if you can still get them tho.
Jim J. (WA)
11-29-2005 05:15:08
 Re: block heater dimention in reply to Duner Wi, 11-28-2005 20:03:17
Hey Dell
you say not to bother with dipstick heaters, but not why. would you please explain?
Thanks..... .Jim
Rusty 2N
11-29-2005 08:38:44
 Re: block heater dimention in reply to Jim J. (WA), 11-29-2005 05:15:08
They tend to cook your oil.
