Live lift 2
Mike H(MD)
04-19-2001 08:35:40
I just read about Zanes idea about running the inlet from the new pump into the port on the side. The only problem I see with that is that is the output side from the orig. pump and you will have no control of your lift(constant up)as the control lever is on the back side of the pump. you would have to plumb in another contol lever...Mike
Mike H(MD) info for Zane,
04-19-2001 13:56:28
 Re: live lift 2 in reply to Mike H(MD), 04-19-2001 08:35:40
Zane check to see if I'm mistaken...Mike
