To begin with the front mount distributor cannot be installed 180% out of time because the tang that engages the distributor is off centered so that it is impossible to do it wrong. If the distributor is installed without the tang turned the correct way the distributor housing will be broken when the two retainer bolts are tightened. If the point gap is not correct the timing can be adversley affected. Too close and the ignition is late. Too wide and the ignition is too early. I'm not that good at mathematics but I think that one thousands on the points gap equals about 3 degrees on the ignition timing. Maybe more. Claus! Where are you? Also the slot in the cam gear will wear on the driving side and this will cause the ignition to be later. I just last week got a tractor to repair that the points could not be adjusted because the aftermarket front mount distributor was made wrong. The screw holes were not in the right place for mounting the points that would have made it possible to properly adjust the points. I had to modify the points holes to make them work. It was not the points either because I tried an old original set for comparison. It was a mis made distributor plate. On this particular distributor (after market) the tang that engages the cam slot was barely exiting the back of the distributor because of the front bushing holder being mis-made making the whole shaft move forward about an eitght of an inch. This had a bearing on the timing too because the tang was barely making up with the slot. The slot being worn already multiplied the effect making the ignition timing very late.
