Inside Paint Job
John.UT
04-18-2001 10:16:52
Anyone have a reccommendation what paint to use on the inside of the tractor? It will have to hold up to submersion and splashing of the hydraulic oil.
Thanks
bg
04-18-2001 10:21:19
 Re: Inside Paint Job in reply to John.UT, 04-18-2001 10:16:52
Some recommend a red spray insulating coating like Glyptol. Most electric supply houses carry it, as well as WW Grainger.
Salmoneye-huh?
04-18-2001 10:49:13
 Re: Re: Inside Paint Job in reply to bg, 04-18-2001 10:21:19
Was the whole inside painted, or are you talking about just the tranny cover?
John.UT
04-18-2001 11:43:08
 Re: Re: Re: Inside Paint Job in reply to Salmoneye-huh?, 04-18-2001 10:49:13
Mainly I want to touch up the inside of the lift cover and lift cylinder. But I would like to also touch up the axle housing and ring gear.
Dave Smith
04-18-2001 18:44:24
 Re: Re: Re: Re: Inside Paint Job in reply to John.UT, 04-18-2001 11:43:08
I have just started a tear down on my 48 8N and intend to paint the inside of my engine with Glyptol, I once had a 67 Jeep 327 and had to change a hydrolic lifter. When I took the intake off i found the inside painted with Glyptol and it was so clean you could almost eat off of it. We used it in the plant to paint motor windings etc. Also used to paint control room floors It is a non electrical conductor and grease and oil will not stick to it.
Dave Smith <*)))><
