Order Ford 8N Parts Online
8N Problems
John Thatcher
04-16-2001 19:09:09
I have an 8N. It will not run unless the choke id closed. I have rebuilt the Card and the Govenor. What else can be wrong?
HELP me
RockyMountain8N
04-18-2001 06:26:26
 Re: 8N Problems in reply to John Thatcher, 04-16-2001 19:09:09
Screw the mixture jet out a couple more turns. I rebuilt my carb and followed the directions in the kit. Result was a mixture so lean that I had to choke it to run. In desperation I opened the jet up and after getting it running, set mixture properly.
LOREN
04-16-2001 19:21:26
JOHN,
HAVE YOU INSPECTED OR REPLACED YOUR MANIFOLD GASKET. IT MAY BE LEAKING. OR IS THE MANIFOLD ITSELF IN SATISFACTORY CONDITION? POSSIBLY RUSTED OUT?
WORTH LOOKING INTO !!!
michael
04-16-2001 21:33:17
 Re: Re: 8N Problems in reply to LOREN, 04-16-2001 19:21:26
After checking manifold, my first thought is-is th ecarb getting enough fuel from the gas tank? have you taken the line loose at the carb to see how much is coming out?
John Thatcher
04-18-2001 15:13:08
 Re: Re: Re: 8N Problems in reply to michael, 04-16-2001 21:33:17
Nice stream of gas flows, WEIRD huh?
John Thatcher
04-17-2001 15:37:50
I have had the carb off so many times I can see it in my dreams. I have rebuilt it and cleaned what was nor in the kit.
steve
04-17-2001 06:12:43
Sounds like fuel, also be sure to check the filter screen on the elbow fitting where the lina attaches to the carb
498N
John Thatcher
04-18-2001 15:14:49
 Re: Re: Re: Re: 8N Problems in reply to steve, 04-17-2001 06:12:43
I replace the screen and have checed it several times since in the thought that something was contaminating the gas
John Thatcher
04-17-2001 15:40:09
Did that too, replaced the screen at thr taank strainer, removed the screen at the acrb and cleaned it.
