Lift control lever bind?
Dave 50 8N
04-16-2001 09:01:05
I used a heavy disc a few weeks ago, and now my lift lever has a spot that kinda binds/catches, just a little. But it is easily pushes past that part. It appears to be something internal.
The lift still works aok, but this is a change from before, and I'm just wondering if this is a warning sign of a repair coming my way.
thanks in advance!
ZANE
04-16-2001 19:26:45
 Re: lift control lever bind? in reply to Dave 50 8N, 04-16-2001 09:01:05
It is common for foreign material to get in between the mating surfaces of the control valve and caust them to bind and sometimes stick.
You may need to drain the lift and rince it out good with five gallons of kerosene by pouring it through about 3 or 4 times and not letting the settlings in the bottom go back in the lift.
Then replace the five gallons of oil afte draining all three places.
