Order Ford 9N Parts Online
9n/2n
Michael
04-15-2001 16:41:39
So what your telling me is the 9n hydralics only go up or down? what is the little lever under the seat of an 8n for?
Claus
04-15-2001 18:09:39
 Re: 9n/2n in reply to Michael, 04-15-2001 16:41:39
The 8N has a fourth gear that the 2N/9N does not have. So when one really honks in forth gear the lever will let out the drag shute to slow one down.
Happy Motoring
Claus
ED
04-15-2001 20:25:53
 Re: Re: 9n/2n in reply to Claus, 04-15-2001 18:09:39
I thought that was for the ejector seat.
Steve IA
04-15-2001 17:48:07
The little lever is vertical for "Position Control" wherein you should be able, on a properly working/adjusted hydraulic system, to adjust to any position using the quadrant and the hydraulics will magically keep it at that position. Up, down, in between. You name it, it do it. In the horizontal "Draft Control" lever position, you basically have an up or down choice with the quadrant. This position is used for plowing and other ground breaking type activities. The absence of this added Position control feature on 2/9Ns can be overcome with the ZaneThang. HTH Steve 8N 169302
