3-pt trouble
Bruce Daman
04-12-2001 19:58:22
I am having trouble with my 3 pt hitch. It seems to work sometimes. The lift arms will move up and down with the control level on the side of the tractor, usually. But when hooked to an implement then will lift, but wont lower when level is moved. If the tractor is turned off and the lever moved the lift arms will then lower. This problem does not seem to happen all the time. Any ideas on were to start with a fix? Do you think its in the hydraulic pump? Is there a bleeder port of something that could be plugged? Maybe it needs new oil, or a flush. And help would be great. Thanks.
Ken N Tx
04-13-2001 04:56:01
 Re: 3-pt trouble in reply to Bruce Daman, 04-12-2001 19:58:22
9N on 8N..Could be the relief valve or control fork..Check archives..
