Order Ford 8N Parts Online
8N on and off over heating
Laurence
04-10-2001 21:09:39
Does anyone have an explanation for why my 49 8N apears to be overheating randomly. Sometimes there's only a trickle of coolant leaking from the cap, and other times it leaks out enough to bother the front mounted distributor/coil and then other times no signs of trouble. I bought a new cap with no perceived improvement.
bj/8N/mt
04-11-2001 07:34:07
 Re: 8N on and off over heating in reply to Laurence, 04-10-2001 21:09:39
are you sure the thing is overheating or is it just pushing coolant from being over full
the cooling system on these tractors is way over engineered so if it truely overheats you need to check the thermostat by boiling and make sure the fan belt is tight enough that you can't turn the fan with the engine off
what is more likely is that the system pushes the coolant it doesn't want when you fill it. at least on my 8N's it will push until the top of the core is just barely covered.
your mileage may vary
LOREN
04-10-2001 22:05:42
ARE YOUR HOSES O.K.? DO THEY HAVE THE METAL SPRING IN THEM TO KEEP THEM FROM COLLAPSING? NOT THAT YOU NEED THE WIRE AS MUCH AS ALL OF IT BREAKING LOOSE AND CAUSING BLOCKAGE. IS YOUR THERMOSTAT O/K.MIGHT NEED THE RADIATOR CHECKED IF YOU ARE CERTAIN OF ALL THESE.
TimK
04-11-2001 21:31:23
 Re: Re: 8N on and off over heating in reply to LOREN, 04-10-2001 22:05:42
I agree with the other responses. N's have really big cooling systems so if the system is ok, you should not overheat. To add, you have to keep the coolant about 2" below the cap otherwise even a good system on the N will overflow. You also have to have molded hoses, ones that are made for the N. Get those from this Board or NH. Finally, why don't you change the thermostat just to make sure that's not the culprit (it's cheap). Finally, make sure there isn't any leaves or other debris in the radiator. I assume that you are running the proper percentage of coolant, if you are not, you could have a lower boiling point. My $.02
