Order Ford 9N Parts Online
9n Tranny oil level?
Bob In Iowa
04-10-2001 10:03:35
My 9n does not have a dip stick for the tranny oil. I know there is a bolt to take out to get the right level but I not sure witch one it is. Thanks Bob
Check Plug Pic
04-10-2001 13:58:48
 Re: 9n Tranny oil level? in reply to Bob In Iowa, 04-10-2001 10:03:35
Here's a pic of the early 9N oil level check plug. I don't remember seeing an upper and lower plug. I just have one that checks the upper level. Fill until she starts coming out of hole (level ground).
third party image
third party image
I believe it was in '41 when the dipstick was moved back to the right hand inspection plate.
Tyman
ED
04-10-2001 14:33:25
 Re: Re: 9n Tranny oil level? in reply to Check Plug Pic, 04-10-2001 13:58:48
You are right - I must have been thinking of our old Farmall H. I think that had two plugs for engine oil.
Ken N Tx
04-10-2001 12:05:38
If you have a Hydro Dipstick, it is the same for the trans...5 gal..Hydro and trans use the same fluid..
bj/8N/mt
04-10-2001 11:05:00
until you can raise the four dollars a new dip stick costs you can use the engine oil dip stick
should bottom out around with the collar around three inches above the tube and read close enough for government work
your mileage may vary
ED
04-10-2001 11:14:57
 Re: Re: 9n Tranny oil level? in reply to bj/8N/mt, 04-10-2001 11:05:00
I think he is talking about something different. The early 9Ns had two plugs in the side of the trans. One high and one low. Fluid was supposed to be filled until it ran out of one of them. That was how you knew you had enough. Unfortunately I don't know which one.
