6 or 12 volt coil
David (ky)
04-07-2001 15:54:46
Iv'e got a 9n with front dist/square coil and i think my coil is bad...i'm getting juice to the coil but no fire to my plugs...its been converted to 12 volts but i don't see any voltage reducer.can't find my meter and with my 12 volt idiot light it seems iv'e got the same voltage at the coil as i do every else...theres no writing or anything on the coil to say if it is 6 or 12 volt....thanks for your help and time..... ..
Dell (WA)
04-07-2001 16:53:12
 Re: 6 or 12 volt coil in reply to David (ky), 04-07-2001 15:54:46
David..... ..As I understand your information, your test light indicates that you are getting electricity at the frontmount coil terminal. Take the coil off and leave the terminal connected and see if your test light works on the underneath coil terminal. Light should light on both terminals, 1 bright, 1 very dim. If not, yeah, probably a bad coil.
My guess right now, is your points are not working, take your frontmount distributor off (2 bolts) and check the points gap.
There are a number of excellent 12 volt conversions web pages out there with pictures, just do a search. Also, check the "archives" at the top of this most excellent N-Board. Read and weep at the trials and tribulations of the electrically challanged.
Sorry, I can't tell you more specifically what is wrong with your 12 volt ignition conversion. I flunked mindreading, just ask my ex-wife..... ..Dell
David (ky)
04-08-2001 07:18:38
 Re: Re: 6 or 12 volt coil in reply to Dell (WA), 04-07-2001 16:53:12
thanks dell.....i checked and i get a bright reading on both terminels and my points are new and gapped at .014...the onley other thing i can think of is that its my dist cover or condenser....thanks for your help dell
Dell (WA)
04-08-2001 13:00:07
 Re: Re: Re: 6 or 12 volt coil in reply to David (ky), 04-08-2001 07:18:38
David..... ..you report both bottom coil terminals "bright". I said that you should have 1 bright and 1 dim. Replace your coil..... ..Dell
