Starter field coil brushes, Dell, Claus, Phil???
Jim
04-07-2001 15:05:30
Hey guys, I have disassembled my starter to rebuild it (all brushes less than 1/4 inches, had no trouble with it before I started my total engine overhaul -bearing problem) I only have one question
What is the best way to R & R the field coil brushes (soldered at the connection)? I read in the archieves thet this connection is special, requires very high heat to R & R. Should I take it to a local starter/generator repair shop and let them do the field coil brushes?
thanks for the advice, Jim
Claus
04-07-2001 15:13:54
 Re: Starter field coil brushes, Dell, Claus, Phil??? in reply to Jim, 04-07-2001 15:05:30
You need one of those big fat soldering irons about 300 watts. Unless you know what you are doing, then take it to the shop..
Happy motoring
Claus
STUMP PULLER
04-07-2001 20:58:36
 Re: Re: Starter field coil brushes, Dell, Claus, Phil??? in reply to Claus, 04-07-2001 15:13:54
I USED A SMALL TORCH AND IT WORKED REAL NICE. JUST DONT OVERHEAT ANYTHING. GOOD LUCK
