4th Gear no power. Need help!
Mike 8N
04-07-2001 13:16:26
I recently cleaned out the screen filter in the tank. Ever since I seem to have very little power in 4th gear at low rpm. It will not get up an incline where before it was fine. Does this sound like carb adjustment, or clogged fuel supply. The supply seemed ok when checked at the float bowl drain plug. It did not gush out but was a steady stream. Thanks for the help.
Dell (WA)
04-07-2001 17:31:30
 Re: 4th Gear no power. Need help! in reply to Mike 8N, 04-07-2001 13:16:26
Mike..... .sound suspiciously like you might have your governor arms crossed. Short arm to the carb throttle shaft. Long arm to the dash throttle shaft. ..... .Dell
Steve IA
04-07-2001 13:39:38
You do remember there is another screen inside the brass elbow as it goes into the carb. You may have dislodged something cleaning the tank screen. I would check the elbow screen and probably go ahead and clean the carburetor. That's what I'd do. HTH Steve 8N 169302.
Snowplow
04-07-2001 18:43:56
 Re: Re: 4th Gear no power. Need help! in reply to Steve IA, 04-07-2001 13:39:38
I agree that you might have stirred up some gunk that is now inline. If you had power before you should have at least equal now.
Check the screen that is in the brass fiting where the fuel line enters the carb. Also check the sediment bowl screen.
You may also just need a carb adjustment and or new plugs.
Thanks, seems better now.
04-08-2001 14:19:55
 Re: Re: Re: 4th Gear no power. Need help! in reply to Snowplow, 04-07-2001 18:43:56
I cleaned two of the three screens, cleaned and regapped the plugs, and adjusted carb mixture. Been out discing for the last two hours. Thanks again.
