Order Ford 8N Parts Online
8n PTO speed?
C kennedy
04-07-2001 10:36:55
Does anyone know what the PTO RPM is on an 8n?
Ed Gooding (VA)
04-08-2001 03:19:30
 Re: 8n PTO speed? in reply to C kennedy, 04-07-2001 10:36:55
In addition to what the Jim's told you, here's a chart that will give you the max numbers:
third party image
Hope this helps..... ..... Ed
'52 8N475798
Jim
04-07-2001 10:48:18
C, The PTO speed is directly proportional to the engine speed. From the operators manual 1500 rpm engine speed is approx 545 PTO rpm. This also happens to be the recommeded PTO operation speed from FORD for the tractor and most common implements you would use on a 9/2/8N are designed to operate at 545 PTO rpm. Somebody a long time ago thought 545 was a good number, I guess!?$#
Jim
Jim.UT
04-07-2001 10:46:32
It varies with engine speed. Makes it tough to get the right speed without a proofmeter (tach). I suppose with enough experience you could learn to tell by ear. That's probably why the later 8Ns and all the later tractors came with a proofmeter. For those with earlier tractors, Duane has hit on a solution in the form of a digital tach mounted on his dashboard. Scan down to yesterday's posts (or maybe the day before) and you'll see it. Once you know the engine rpm you can mathematically figure the pto rpm....or you could just ask these guys and one of them can just tell you.
