? Positive Drive Starter?
Jim, DITTO ,I A
04-06-2001 11:21:36
Guys, Latest question on my engine rebuild.
When I removed the engine, I noted that the bendix drive was still engaged, at the flywheel. This answered my "What is that racketing noise in the engine as I hand turned the engine over to check the rod bearing clearances?" (The bad bearings is why I am doing the rebuild). I am only familiar with solinoid driven and spin-out driven bendix. Both disengage the flywheel upon startup. If this is one of those "positive drive" things, is it always engaged with the flywheel? What should I look for, p/n, appearances, etc that will confirm that I have a "positive starter drive"???
thanks for your help, Jim
don b
04-06-2001 15:12:45
 Re: ? Positive Drive Starter? in reply to Jim, DITTO ,I AGREE!, 04-06-2001 11:21:36
The most common diff is the pos. dr. DOES NOT have the big spring on the drive.I strongly reccomend the PD drive. don
Jim DonB?
04-06-2001 17:28:44
 Re: Re: ? Positive Drive Starter? in reply to don b, 04-06-2001 15:12:45
Don, My drive has no spring on the end (as shown in the parts manuals). Is this type of PD drive always (all the time) engaged with the flywheel? Mine seems to be (maybe) stuck in the pushed out (engaged) position. No hand manipulation in any direction seems to let it retract towards the end of the shaft. Of note, Just prior to removing the engine from the tranny, I had used the starter to turn over the engine to loosen the head with compression strokes. Would this cause the PD drive to "lock" in the engaged position?
Thanks for all the help and info, Jim
Dell (WA)
04-06-2001 21:11:31
 Re: Re: Re: ? Positive Drive Starter? in reply to Jim DonB?, 04-06-2001 17:28:44
Jim..... ..no, using your starter to drive your pistons to pump off the cylinder head should not jam any starter drive unless your really have problems.
The starter drive should "retract" when you remove the electricity. The reason the starter drive "retracts" when your engine starts is engine turns faster than starter motor thus driving the bendix gear out of the flywheel ring.
You seem to be confused as to what a Positive Drive starter clutch setup looks like. Stop by your local autoparts house and ask to look at one. My 1972 390-V8 Ford had one in for reference. ..... ..Dell
Martin D.
04-06-2001 18:29:56
Jim
What you describe is exactly the way a PD drive works. The drive will only disengage when the engine starts and centrifugal force allows the drive to retract. You can disassemble it and cheat but it is not an easy job. I know this from experience as I had just manually extended my brand new drive when the partsman said "don't fool around with that". He was a second too late and I had to spend a lot of time getting it back in place to install it. You can spin it really fast with a drill and it will go back in place if that suits you better. Good luck.
STUMP PULLER
04-06-2001 12:12:43
IT SHOULD WORK LIKE THE OTHER POST DESCRIBED. SOMETIMES THE BENDIX GETS JAMMED BECAUSE OF THE POOR CONDITION OF THE FLYWHEEL RING GEAR. SOMETIMES THE BENDIX GOES BAD. MINE IS MARGINAL AND OCCASSIONALY STAYS ENGAGED, AND WHEN IT DOES I CAN HEAR THE NOISE OF THE STARTER CONTINUING TO TURN. IF I STOP THE ENGINE AND RESTART, IT USUALLY IS OK. I JUST HAVE TO GET A NEW RING GEAR SOMEDAY. I WOULD LOOK AT YOUR BENDIX AND STARTER REAL CLOSE AS LONG AS YOU GOT IT APART. GOOD LUCK
Kevin CO
04-06-2001 11:46:15
My understanding is that the drive stays engaged untill the engine spins it fast enough to "throw" it out of engagement.
I know mine stayed engaged until I finally got her started.
