!OT) Bolens Riding Mower Quit
Doug (OH)
05-22-2005 17:16:20
I jumped started it from a marine battery not hooked up to anything else. Then for the next 3 or 4 times it cranked fast and started fine. So I use it, turn off the key and 10 minutes later I go to start it and nothing. Battery checks out but starter doesn't crank or make any sound. Any help appreciated. Thanks
souNdguy
05-23-2005 06:42:49
 Re: !OT) Bolens Riding Mower Quit in reply to Doug (OH), 05-22-2005 17:16:20
Is it possible that the battery is bad?
Do the cleaning the other poster sugested.. if it doesn't turn over.. tap the starter with a wrench or hammer. if this makes it turn over... time for starter or solenoid work.
Soundguy
rbell
05-23-2005 12:56:34
 Re: !OT) Bolens Riding Mower Quit in reply to souNdguy, 05-23-2005 06:42:49
One should always take pliers and jump across the solinoid to determine if the battery is low or bad.
WORD OF CAUTION
Jumping across the solinoid circumvents all starter saftey switches (blade seat etc)
rbell
05-23-2005 06:13:44
check and clean the battery connections (especially both ends of the ground ), and insure their is good clean contact between the solinoid and the chasis.
