Order Ford 8N Parts Online
49 8N Rear Axle Seal Questions
Kev8n
04-02-2001 18:53:08
I have a '49 8N Serial 217440 which I'm working on to stop the leaking seals on the real axles.
Tonight, I took off the left brake drum, brake pads, springs, etc. Looking at diagram FO121 in the FO-4 manual, which of the seals would I need to replace to fix the problem.
The manual shows a gasket and a oil seal (outer) then a seal that fits into the bearing retainer is also called outer oil seal. When I took it apart, I don't remember seeing a seal in it. There is also listed an inner seal.
I'm pretty sure FO121 represents my tractor, just not sure what parts I should get to fix it.
Any help would be greatly appreciated.
Kevin
'49 8N '53 Golden Jubilee
Kev8n
04-03-2001 16:37:51
 Re: 49 8N Rear Axle Seal Questions in reply to Kev8n, 04-02-2001 18:53:08
Dell:
Thanks for the info. I picked up the parts from a local dealer and should be working on it this week. I also picked up the cork seal for the Axle bearing.. so I'll soak it up about an hour before use.
Thanks again. I'll let you know how it goes.
Kevin
Dell (WA)
04-03-2001 00:53:54
Kevin..... .in my opinion, the problem with FO-121, it is distorted which leads to confusion.
#6 Oil seal retainer assy, outer, p/n A8NN-4248-A, consists of #7 Gasket, Outer Bearing Seal p/n 8N-4290, and #8 Oil seal Outer, p/n A8NN-4251-A.
When I replaced axle outer seal, it was cheaper to replace the entire #6 Oil Seal Retainer Assy, with p/n 8N-4251-C. (which has superceeded A8NN-4251-A or 8N-4251-B)
Be sure to have a lotta extra p/n 8N-4229-D shims (0.010) as some will invaribly be broken/cracked and there only about 50 cents. Make a deal to return your unused ones with the parts guy. Sometimes they'll sell you a paper gasket type instead of metal, eather works. Recommend you use some silicone pucky on the shims at the axle trumphet/brake backing plate interface for leak prevention.
FO-4 manual for adjusting clearances is pretty strait foward, just kinda distorted picture.
Also be certain to pack your 2N-4221, axle shaft bearing, with good longfiber tractor axle greese..... ...Dell
Ringy
04-02-2001 22:06:51
Check out the archives for Zane's silicone in axle trumpet solution. He posted good directions and two pictures about a month ago. Mine leaked really bad and that fixed it for me. I've gone two years without a drop leaking out.
