Order Ford 8N Parts Online
8N Hydraulic Pump gasket replacement
Joel
04-01-2001 19:04:00
I tried to replace the gasket on the oil pan side of the hydraulic pump, the pump wouldn't come out because somehow it is clipped from the inside. I read in the IT manual, I never attempted to change the gasket before on the hydraulic pump and am not sure how to go about this. If anyone has ever done this and can guide me through this it would be appreciated, thanks.
Mountainman
04-01-2001 21:21:40
 Re: 8N Hydraulic Pump gasket replacement in reply to Joel, 04-01-2001 19:04:00
Drain fluid � three drain plugs
Remove PTO shaft Remove Hyd pump
Since you have already tried to remove the Hyd pump, be sure to replace a couple of bolts to hold it in while you remove the PTO so the pump won't drop out. As I recall, you might have to drop down one end slightly them slide the pump forward or backwards slightly to get it out.
Hope this helps.
Mountainman (CA)
