AFTER MARKET FRONT MOUNT DISTRIBUTOR PROBLEM
ZANE
04-01-2001 19:03:43
Today I had a neighbor bring in his distributor for me to try to set the points.He just bought it a few weeks ago and the tractor has not run right since he put it on. He said that he had the thing off about a dozen times and could not get the points to set right and the timing was way off.
The first thing I saw was that the drive tang was so far back in the bushing in the housing that it probably was just barely catching the slot. It is possible that this was cause by someone tightening the bolts when the tang was not properly seated in the slot but I don't think so. I think that the distributor plate and end bushing that goes under the rotor was just manufactured wrong by about an eigth of an inch.
I put the base of the distributor in the vice for support and bent the supports of the front bushing down until the tang was even with the big brass bushing so it would engage the slot in the cam gear enough.
Then I addressed the points. At maximum wide I could only obtain about .002 clearance between the contacts. I believe that the distributor plate is machined wrong. I took the points out of the distributor and elongated the screw holes enough so that I could get the .015 clearance. The next person to go into this distributor is going to have trouble. I think it will run OK now. Tell you more when he puts it back on the tractor.
Al English
04-01-2001 19:29:07
 Re: AFTER MARKET FRONT MOUNT DISTRIBUTOR PROBLEM in reply to ZANE, 04-01-2001 19:03:43
Hi Zane, There was also a post recently about replacement front mounted distributors with cams that are not machined symmetrically...Al English
RON/PA
04-01-2001 19:22:43
ZANE, PLEASE LET US KNOW HOW IT TURNS OUT!!!!
I HAD TO ELONGATE THE SLOT ON A SET OF POINTS INSTALLED IN AN AFTERMARKET DISTRIBUTOR, AND I HAVE BEEN SWEATING BULLETS EVER SINCE. THAT WAS ALL THAT I COULD SEE TO DO, AND I DO NOT LIKE TO THINK OF A UNHAPPY CUSTOMER RETURNING BECAUSE OF MY RIGGIN. ALL ELSE LOOKED GOOD AND I AM STILL THINKING THAT I MISSED SOMETHING ELSE. THANX
RON/PA
