Order Ford 8N Parts Online
8N Stuck hydralics
Bill King
03-31-2001 19:58:41
The last couple of times I have mowed with my 52 8n, after 30-45 minutes my hydraulics "involuntarily" raise to highest position and will not go up or down. After I shut off the PTO and drive it back to my shed, the shredder will normally go back down after about an hour. These two times, I have quit for the day so I am not certain if or when it would repeat itself. Any ideas, help or something I'm doing wrong? Thanks for any input.
ZANE
04-01-2001 19:49:16
 Re: 8N Stuck hydralics in reply to Bill King, 03-31-2001 19:58:41
You should drain the lift and try rinsing the lift chamber out with clean kerosene. Pour it through the lift several times leaving the sediment in the container each time. Then replace the oil. Use either 90W or 134. According to the temperature of the air. If it is cold use the 134. If it doensn' have any significant leakage the 134 will work OK in temperatures up to about 90%.
Be sure to drain the other two comparts too after the kerosene cleaning to get it all out.
bill king
04-02-2001 20:04:03
 Re: Re: 8N Stuck hydralics in reply to ZANE, 04-01-2001 19:49:16
Thank you Zane. I'll give that a try. I have only had the 8-N for a couple of months and I am still learning. I have all three manuals and use them as well as this site. By the way for anyone who reads this. This is a great site and today, I sent them my voluntary subscription fee. Keep the good info coming.
