Order Ford 8N Parts Online
Can 8N pull a 6 foot finish mower?
johnstaci
04-21-2005 22:13:20
Have a 52 8N and have been using a 5' brushhog. Would like to get a finish mower- preferable 6' so I don't have to run over my tracks twice each mowing.
Will there be any problem pulling a 6' finish mower behind an 8N?
Paul Leske
04-22-2005 11:47:54
 Re: Can 8N pull a 6 foot finish mower? in reply to johnstaci, 04-21-2005 22:13:20
I use a 6' King Kutter on my 8N with no problems.
Bruce (VA)
04-22-2005 05:08:46
No problem; I pull a 6" Caroni over 3 acres of grass all summer behind my N"s. But, like others said, use an ORC & remember, it is a big lawn mower, not a bush hog!
Barnstormer
04-22-2005 04:06:28
I've been pulling my Woods 6' mower behind my '51 and '52 8Ns for 18 years. No problem except when I don't sharpen the blades or the grass gets too tall.
Don't forget to install an over running clutch (ORC) on the pto shaft.
Bob
04-21-2005 23:52:46
You should have no problem if you use the mower within it's design limits, as a "finish mower".
Don't expect to chew through foot-tall grass and weeds, though!
Rob 9N
04-21-2005 23:28:41
John, I use a 6' King kutter with great results. My biggest problem was using it like a bush hog. Running over medium sticks and limbs. Much better on grass only. Hope this helps. Rob
Pooh Bear
04-21-2005 23:27:34
Does it run good and is the clutch in good shape.
Then it should pull a 6 footer no problem.
Pooh Bear
