Order Ford 8N Parts Online
8N Cut Out On Me
Jim
03-30-2001 07:44:44
Without warning, my 8N shut off on me like I had turned the key off. It has gas, I replaced the points, condenser, cap, solenoid and had the starter checked out last fall (Sept '00) because it wouldn't start. It won't re-start now and it sounds like the solenoid is shot again. Is there something else going on (coil, etc) that I'm missing here? Someone told me they are hard on points. Any help or advice is greatly appreciated
Chuck
03-31-2001 08:49:29
 Re: 8N Cut Out On Me in reply to Jim, 03-30-2001 07:44:44
Had a similar problem which turned out to be a flaky ignition switch. Installed a new one and no more problem.
Hope this helps!
Chuck
Jimp CO
03-30-2001 13:33:23
Here is from another JIm.
Lets take a couple of steps in trying to figure this out.
1. Do you have Gas flowing? take the breather tube off and (in Nutral) crank it over and spray either ether or WD40 into the carb. opening. Not a lot... If it starts, then you have fuel problems.
2. Pull a plug wire and see if you are getting a nice blue spark.
If not then you have electrical problems.
Jump across the key switch and see if you get spark.
If not, then check all of the wires into and out of the distributor.
OK? then take the cap off and see if you are getting spark across the points. Are points set correct?
if you still don't find the problem, check the voltages at your battery, battery to resistor/s, resistor/s to coil. coil to points.
Need to know if this is a 6 or 12..V. system. front or side mount dist.
Hope this helps in starting to track down the problem.
Get back to the board with what you have tried and what the results were.
LUCK, hang in there and it will run again.
Jim
03-30-2001 13:14:41
Jim from another Jim,
I'm going to assume that when you said "Without warning, my 8N shut off on me like I had turned the key off" you had the tractor running and it just stopped. This would have nothing to do with the starter, but an ignition switch or dist/coil area would seem like a logical area of concern. Be sure you don't have a fuel problem, filter or line plugged somewhere.
This board can help you. The more details you provide the better. Be sure to list specifically what happened, when, under what conditions. Then specifically what actions you have taken and the results. The more details, the better!!!!! these are the valuable hints and clues as what my be wrong.
Hang in there, The other Jim.
Phil (AZ)
03-30-2001 11:04:58
Jim, "It won't re-start now and it sounds like the solenoid is shot again"
Why would you think the solenoid is bad ? The killing Zone for Solenoids is when the Battery is almost dead and you get the "Clicking" sound
Ignition Quick Check:
When your engine is cranking.. look at the ammeter (ignition is the only load) and if the meter is fluctuating ..it means the points are opening and closing. Bumping the starter until you get a steady current (points are closed) and read the ammeter 2.4 - 3 Amps (Front Mount) 6 amps side mount.
Hope this helps
bj/8N/mt
03-30-2001 08:23:05
More information?
is the trouble that the starter doesn't crank?
is the trouble that it cranks but there is no fire at the plugs?
what is the voltage at the coil?
like Dell says--mind reading is done on a different board
