Order Ford 8N Parts Online
8N hydraulics bleed down
Michael
03-28-2001 12:27:34
The hydraulics on my '47 8N tend to bleed down after a few minutes with the PTO disengaged, especially with a heavy load attached. I heard or read someplace that it is possible to replace the 8N piston with one from a Jubilee or NAA that has the "O" ring rather than the metal rings. Is this true? Do I have to switch the cylinder? If I wanted to switch the cyclinder, will one from a Jubilee work? The hydraulics on my Jubilee will hold up a load for a week. I would like to try this so any help would be appreciated. Thanks.
don b
03-28-2001 13:15:05
 Re: 8N hydraulics bleed down in reply to Michael, 03-28-2001 12:27:34
Piston is interchangeable but cyclinder is not.Leakage may be due to the piston or relief valve.You can replace both for less than 50.00. don
TimK
03-28-2001 14:42:33
 Re: Re: 8N hydraulics bleed down in reply to don b, 03-28-2001 13:15:05
While I don't disagree with the other response, take a look a the archives on this Board and look for Zane's diagnosis procedures for hydraulic problems before you start tearing into anything. Might save you some work and $$$$$'s. My $.02
