Installation of sure seals
Terry
03-27-2001 11:33:15
Does someone know how these are suppose to be installed, do they just slipp on axle or are they suppose to be pressed into the bearing holder?
Bill(Tx)
03-27-2001 19:03:06
 Re: installation of sure seals in reply to Terry, 03-27-2001 11:33:15
Click on the link below for a step by step.
third party image
Steve(MO)
03-27-2001 18:56:12
I put a pair of sure seals in my 2n last fall. Pretty much the way Beekeeper said. They were a SNUG fit in the bearing holder. I fought with that for a while. Finally beveled the edge bearing holder slightly with a dremel to help get it started. Also, since you're isolating the wheel bearings from the oil, you'll need to pack the wheel bearings with grease before you tap the seals in place!
Since I'm a belt & suspenders kind of guy, I applied Zane's unconventional repair method also. I've only got about 50 hours on it since the repair, but so far so good.
ZANE
03-27-2001 18:38:36
When it leaks the next time try my fix for those leaky rear axles on the tractors that didn't have the inner seals in the trumpet houshing. I have not had one leak yet that I have fixed this way.
To fix the leak my unconventional way you pull the axle away from the axle housing about 6 or 8 inches and wrap the axle for about 6 inches from the outer end of the axle that is exposed with teflon tape.Wipe all the oil from the housing and then take a caulking tube full of silicone glue and pump it into the void between the axle and the housing. Keep the hub as close to the housing as you can till you get the silicone pumped in.Use the whole tube and then replace the axle into the housing and replace the bolts etc. Let the silicone cure overnight and then you can go about using the tractor. Be sure that the oil in the rearend etc is not over full as this will contribute to the axle leaking.
Beekeeper
03-27-2001 11:45:19
Terry,
Wipe down your axle and coat it with a bit of oil. Slide the sure seal onto the axel. The sure seal snugly fits inside your bearing holder (make sure you have it full of grease). You can press it in or carefully drive it in (this is the worst part). Just make sure you drive it in straight otherwise it may leak.
Terry
03-27-2001 15:11:34
 Re: Re: installation of sure seals in reply to Beekeeper, 03-27-2001 11:45:19
Thanks
