Order Ford 8N Parts Online
Advice on pitiful 8n
Bill
03-26-2001 17:34:01
In a quandry about procedural methods on pitiful 8n. I plan to remove the spark plugs and try a compression test by hooking battery up and seeing if she turns over. But I know there's years of gunk in the oil pan. Should I drain old oil out and put a tablespoon in each cylinder just for the compression test? I don't really want to pump the sludge back through the motor. Your thoughts, please.
ZANE
03-26-2001 17:55:06
 Re: Advice on pitiful 8n in reply to Bill, 03-26-2001 17:34:01
Why not just change the oil and filter and try to start it. If it runs and doesn't smoke or blow by out the crankcase breather and sounds OK then run it. Forget the compression check! The tablespoon of oil in each cylinder will help it start.
bj/8N/mt
03-27-2001 06:09:17
 Re: Re: Advice on pitiful 8n in reply to ZANE, 03-26-2001 17:55:06
if it were mine I would change the oil and filter making sure the screen is on the base plug and put a teaspoon of oil in each cylinder just as Zane suggests
before I tried to start it I would turn it a few revolutions with the plugs out using a wrench on the crank nut to make sure noting is stuck
your mileage may vary
