Order Ford 9N Parts Online
9N Backfires under load
Tom
03-26-2001 11:20:12
I have a 1942 Ford 9N that I put new rings, valves, valve springs, and a new sleeve in one cylinder. The tractor runs great until I attach the brush hog and begin mowing. Shortly after I begin mowing the motor starts to back fire and loses power. The real problem is that this is the exact same thing it was doing before I did all of the work on it. Does anyone have any suggestions on what else might be causing the problem?
ED
03-26-2001 14:44:03
 Re: 9N Backfires under load in reply to Tom, 03-26-2001 11:20:12
Does the backfiring do away if you pull out the choke? I had a similar problem with backfireing while bush hoging which was fixed by adjusting the main screw on the carb. The locking flange was worn.
However while snow-plowing I also had a bout of the cough and sputters, but only while throttle was up - at idle it was fine. Turned out to be H2O in the distributor.
Good Luck!
TimK
03-26-2001 12:03:28
Backfiring is almost always a function of timing, but sometimes carburation. Ideas: 1) points have slipped out of adjustment
2) distributor shaft is loose in the bushings
3) spark plug wires crossed.
4) Timing is way off
5) carb is leaning out at higher rpm. Poor high speed adjustment, or gunked up carb.
6) Not enough fuel coming into carb at higher speeds, causing lean out. My $.02
Snowplow
03-26-2001 13:33:26
 Re: Re: 9N Backfires under load in reply to TimK, 03-26-2001 12:03:28
My 2N did the same thing. I richened the fuel mix and it ran much better. Also check the fuel flow. Both of these were mentioned above. Weak spark will also show up under load.
