1953 jubeliee naa
Jim
03-25-2001 16:00:38
I am done with my 2n now helping a frend with his 53 naa jubeliee. Well he bout it not running and he has trubble. We found out he needs the back case that the axels bolt to cause it is broke inside. Dos aney one now where one mite be he is in AZ. Also how much will A used one cost. You all hellped me finding parts for mine. Hope you can hellp us. Thanks a lot.
Jim In AZ.
John-COLO
03-26-2001 03:34:34
 Re: 1953 jubeliee naa in reply to Jim, 03-25-2001 16:00:38
I have a good case from a hundred tractor to sell. I'll have to look at it to see if it will interchange. Price would be a LOT less than that $600 number, even with shipping. tOTG
That's fairly common for the NAA
03-26-2001 03:19:03
It seems that the NAA's have that problem. More than one dealer, or parts guy I have seen have had NAA's with a cracked rear differential housings. I know of two rear NAA housings sitting in a boneyard cracked and split. One guy said that he sees those as a common fracture area on the NAA's and over time now, expects to see cracks back there. Before he buys he double checks that area, and if possible looks inside the housing, and has often seen that the crack is hard to weld due to it's location. A rear end? seen them go as as high as 1,ooo,oo and as little as 600.00 You may be able to get by with a 600 Series and possibly 800 series rear end...but look into it and ask that question to a seasoned tractor mechanic.. 9N'er
Russ in SoCal
03-25-2001 21:06:49
Jim,
Try the link below for a bunch of sites in Arizona. I don't know where you are in the state. Hope it isn't near Phoenix or Tucson seeing the mess being made out of two once beautiful cities.
Russ
