Order Ford 9N Parts Online
9N Steering Backlash
H. Libby
03-24-2001 16:50:39
Is there a way to get rid of some of the backlash in the steering box of a 9N short of buying new parts? Thanks for any sugestions.
Tyler (MD)
03-24-2001 17:34:26
 Re: 9N Steering Backlash in reply to H. Libby, 03-24-2001 16:50:39
Thicker outer thrust washers may help. But after most people with this problem start digging into it, they find the sector gears wore beyond hope, especially in the "straight ahead" position of the gears. Those teeth may be wore down to a razor or chipped and broken.
third party image
Only way to find out calls for hood removal and upper steering housing removal. It's lots of work, but when you get her fixed, you'll be proud. Sector gears and pinion are expensive new, used set can be had at boneyard.
Tyman
Duner Wi
03-24-2001 19:10:37
 Re: Re: 9N Steering Backlash in reply to Tyler (MD), 03-24-2001 17:34:26
Would the thicker outer washers come from Ford or what ever they call them selves now??? Thanks
TimK
03-25-2001 16:54:05
 Re: Re: Re: 9N Steering Backlash in reply to Duner Wi, 03-24-2001 19:10:37
Respectfully, I don't want to rain on ya'alls parade, but it ain't gonna work, thicker washers that is. I know, I tried. Reason is because of what Tyler said. The sector gears are mostly worn in the straight ahead postion. this means that when you add thicker washers to take out the lash in the straight ahead positon, it will be too tight in the turning postions. Also, the used sector gears I looked at before I bought new ones for mine looked about as bad as mine, but may you'll be able to hit pay dirt at some bone yard. You may want to take the steering column out and replace the worn parts there, including the pinion shaft in needed, but I think your bottom line is going to be new or used good steering sectors. My $.02.
Tyler (MD)
03-26-2001 03:22:12
 Re: Re: Re: Re: 9N Steering Backlash in reply to TimK, 03-25-2001 16:54:05
Tim's absolutely right. I forgot to mention that when I purchased a good used set of sectors gears and pinion (teeth in straight ahead position), that's when I had to make some other washers. I lucked out when I found a set at a boneyard. I called this boneyard guy up and asked him if he had a good set. He had about 20 9N/2N's in his collection. He went out and found the tightest steering box, disassembled it and sold me the whole upper steering housing for $125. It was off of a 2N.
Tyman
Tyler (MD)
03-25-2001 03:26:51
I'm sure someone has them. Back when I needed them, I made them myself at work using cold rolled steel sheet.
Take care,
Tyman
