Order Ford 8N Parts Online
8N carburetor question
JD
03-23-2001 19:27:56
In an attempt to resolve a cutting-out problem under load, I adjusted the carburetor to a richer mixture. This seemed to help...but I noticed that in order to over-richen the mixture (to find a happy lean/rich medium) and cause the engine to cut-out I had to completely remove the main adjusting needle. Is this a sign of a need to re-build the carb?
Also, I noticed a number 1 next to one of the plug wire connections on the distributor cap. However, the wire that was attached to this one was to plug #4. Is this wrong...and if so, what should the order of connection be? Thanks for any assistance!
Dell (WA)
03-24-2001 00:01:55
 Re: 8N carburetor question in reply to JD, 03-23-2001 19:27:56
JD..... ..N-Engine firing order (wheather frontmount or sidemount distributor) is... 1,2,4,3 CCW.
Believe it or not, the ol' N-Engine is such a good runner, that it will run mis-spark wired, not well, by does run and will seem to run even better if you enrich the mixture by pulling the choke a little..... .Dell
