Order Ford 9N Parts Online
9N / 2N Front Wheels
Tweeter
03-01-2005 04:53:38
Where can I find wheels that are larger than the 4.00-19 for my 2N with the large center hubs?
paul8n
03-01-2005 15:40:38
 Re: 9N / 2N Front Wheels in reply to Tweeter, 03-01-2005 04:53:38
I have a set of 15" and had them foam filled. With the weight of the loader I had nothing but problems with the tires, leaking, holes and too much stress. Costly, yes, but I have no more problems.HTH
George Willer
03-01-2005 07:55:16
third party image
Here's a thought... Bring them over here and swap for the 15" on my 9N. (northern Ohio)
George Willer
Leroy
03-01-2005 16:45:12
 Re: 9N / 2N Front Wheels in reply to George Willer, 03-01-2005 07:55:16
are you sure those wheels are 15"/ look like my 16" on one tractor and have wheels and tires 4x19 that I would trade for 16" wheels only and in Northwest Ohio
George Willer
03-02-2005 06:31:37
 Re: 9N / 2N Front Wheels in reply to Leroy, 03-01-2005 16:45:12
If those wheels weren't 15", I doubt the 15" tires would fit as well. Where in NW Ohio? I'm at Fremont.
Carl S in NH
03-01-2005 11:38:56
Nice looking N you've got there!
Carl S
Jimmyjack
03-01-2005 06:31:23
I have a pair off an 8N in excellent condition that is 15 inch, but Im not sure they will fit a 2N.
souNdguy
03-01-2005 11:01:49
 Re: 9N / 2N Front Wheels in reply to Jimmyjack, 03-01-2005 06:31:23
8n has a small hub, and 9n/2n have a large hub... the rims are not interchangeable.
Soundguy
SteveB(wi)
03-01-2005 06:13:34
There is an ad in the classifieds on the left for 9N 16X6 wheels for big hub. Search ford & WI.It's not me.
souNdguy
03-01-2005 04:58:44
The 3x19 rim was as big as I believe they came from the factory.
What specifically were you looking for?
Some people cut the center out of the larg hub rim, and then weld it into another hub. This was usually done to go to wider tires, etc.. but I guess you could weld the centers into a much larger rim.. say a 24" rim.. then you could look like one of them 'high fashion' decked out cars with the spinning hubcaps.. ??
Watcha planning on doing?
Soundguy
Tweeter
03-01-2005 05:05:02
 Re: 9N / 2N Front Wheels in reply to souNdguy, 03-01-2005 04:58:44
I wanted to add wider tires to the front for a loader. I also like the way they look.
souNdguy
03-01-2005 05:07:39
 Re: 9N / 2N Front Wheels in reply to Tweeter, 03-01-2005 05:05:02
Ok.. When you said bigger.. I thought you meant taller.. not bigger as in wider.
Lots of guys swapped in 8n hubs, and then used the common implement rims. and them wider 3-rib tires.. like 6.5-16, etc..
Course, my previous post info works too.. as you can cut the center out and weld it into a car rim.. etc..
Soundguy
Tractor Rod
03-01-2005 15:47:07
 Re: 9N / 2N Front Wheels in reply to souNdguy, 03-01-2005 05:07:39
Tweeter they did make 6.00x16 rims for the 9N. They were factory, I had 10 sets of them. I will check to see if I have another set. Tractor Rod
