16 rim question
Tim
03-23-2001 06:56:20
The front rims on my 52 8n are rusted about 1/4-1/2 an inch away around the valve stems. Can this be reapaired? Also should I use 11.2-28 or 12.4-28 long bar tires on the rear. I will be pulling two-bottom plows,raking hay, etc. The front tires are 5.50 -16...should they be 6.00-16? This will be a working tractor...but I want it to look good, can you get a durable, nice finish from a spray can paint job or should I go for the real thing? Any advice is greatly appreciated.
Gaspump
03-23-2001 10:25:48
 Re: 16 rim question in reply to Tim, 03-23-2001 06:56:20
Just drill a new hole in a similar location and weld up and fill the old hole. 16" tires were optional on 8N's, dealer installed, and most did come with 5.50X16 but most loader equipped tractors used 6.00X16. The 11.2X28 is enough tire for the power of the N in most soils. Spray can paint jobs can look good but it takes a lot of cans and you can buy good paint to spray for less money and most likely will turn out to be a better appearing and more durable finish.
bj/8N/mt
03-23-2001 11:45:29
 Re: Re: 16 rim question in reply to Gaspump, 03-23-2001 10:25:48
if you do weld your rims put a flap over the weld to avoid chafing the tube. cut up an old tube if nothing better comes to hand
lots of posts about how to prepare paint surface apply equally to rattle cans. if you use enough to do a good job a gallon may come cheaper
your mileage may vary
Brad
03-23-2001 08:34:15
Hi Tim,wanting to by some 5.5 by 16 at tractor supply for the n,but where would i find a more lower profile tire for these?i have been told that normal 16 inch tires would be to tall?is this bad info or should i get what ever fits the wheels?thanks and have a good day...Brad 8n 125807
