Another leaky governor question
Larry
03-22-2001 16:51:14
My governor leaks through where the shafts come through the body. I want to replace the seal and maybe the needle bearings but I can't get the seal out. Is there a trick or do you just pry it out.
Jim
03-23-2001 06:25:23
 Re: Another leaky governor question in reply to Larry, 03-22-2001 16:51:14
All that is fine but I cant get the pin out of my fork. I have broke 2 punches and it wont come out.
I am scared of braking the case. What now????
Thanks
Jim
Mountainman
03-22-2001 22:50:08
You can just pry the seal out but Phil's method is the way to go if you are going to remove the bearing. Hope this helps.
Mountainman (CA)
Phil@TX
03-22-2001 17:10:57
The way I did it was I took a 1/2" drive socket (I don't remember what size) that would just fit over the end. The I took a bolt long enough to go through to the inside. I had a nut and a flat washer on top of the bolt and I screwed a nut on the bottom. Held the bolt with one wrench and turned the nut with another. The nut on bottom must be bigger than the bearing but small enough to not hit the sides of the governor body. Just screw the top nut down and it will pull the seal and bearing out. Hope this helps ya.
