Testing generator
ED
03-20-2001 08:10:46
Can a 6v generator be tested with a multi-meter while installed on the tractor (1946 2N) or should it be taken to a starter shop for testing? This is a follow-up to my question yesterday. I was going to try it this morning, by putting neg. tester lead on generator post and pos. lead on motor, but I thought I would ask first.
The reason for the test is to see if the cut-out relay is working. To recap, while running 1/2 throttle, voltage across the battery terminals reads 5.8 to 5.9 volts. I understand, from Claus, that the voltage should be above 7. If it is possible to test the voltage on the generator, what should it be reading?
As additional info, the previous non-ford generator (which was changed to a rebuilt ford 9mo. ago along with a new cut-out relay) always charged at 20+ amps, so I don't suspect a short of any kind. Since changing the generator (the old one seized up) the amp meter has hovered around 0 amps.
Thanks for the help in advance!
Claus
03-20-2001 11:34:30
 Re: testing generator in reply to ED, 03-20-2001 08:10:46
Of course this voltage I mentioned yesterday is with a charged battery and not a discharged battery. One way to test the generator is to perform a motor test on it. You would disconnect the fan belt from the generator then apply 6 volts to the output terminal of the generator. You could just jumper from one side of the cutout relay to the other to accomplish this. The current draw should be around 3 amps and the generator should turn smoothly.
Happy Motoring
Claus
