Leaky trannie
Larry
03-17-2001 16:18:22
I have a 9N that, like most I've seen has a welded crack on the bottom of the trans case. The problem is that mine has a little leak through the weld. Would something like JB weld put over a very clean metal work? Is there a better way? I don't lose enough to significantly lower the fluid level, but enough to leave a spot if left in one spot for several days.
