Order Ford 8N Parts Online
8N ATTACHMENTS
coshman
03-13-2001 17:43:14
I was at the farm the other day and discovered a rear scoop for the 8N 3-POINT HITCH, it had a trip lever to empty the scoop. Is this 8N "rear scoop" very effective to use?
I also found a "rear boom" attachment for the 8N, it is about 8 feet long with a place to connect a chain on the end. You raise the lift arms to raise the boom and pick things up. It seems to me the the lifting power of the boom would be very limited because of the leverage and the front end of the tractor would come off of the ground.
The attachments are in usable condidion and the 8N is up and running.
I have a chance to buy another 8N that has not been run in several years because it was smoking very bad.
Now here is the question, will the 8N with the rear 3-point hitch boom attachment be strong enough to lift the engine out of the other 8N and set it in a trailer to cary to a machine shop to be rebuilt, and again pick up the rebuilt 8N engine out of the trailer and swing the engine back into the other 8N and stab the shaft and bolt in back in. Of course the other 8N will have been blocked up under the transmission.
This is out in the country and a helping hand is hard to find.
Thank in advance for your responses.
David
Ed Gooding (VA)
03-14-2001 03:51:25
 Re: 8N ATTACHMENTS in reply to coshman, 03-13-2001 17:43:14
Hi David. You had a good day, in my opinion. I use my 3-pt scoop and boom all the time. I've used my boom many times to lift 350 and 400ci V8's out of a pickup bed and back them into my shop and down on a bench. It should handle the flathead 4 with no problems. Some booms have another hitch point for the lifting chain that's closer to the tractor. Use this one for really heavy loads if you find the nose of the tractor inching skyward when you go to lift.
The scoop may only work in one direction if it's the older Dearborn type that looks like this:
third party image
You can only scoop forward with this model, but it can still be useful and folks have actually used them to dig farm ponds. You can also use it to move a load of firewood or other material that you might use a wheel barrow for. You'll get creative with it after you get used to it and find it's pretty handy. I've even used mine to move my mother-in-law around with. I tried to use my boom, but she objected to me wrapping the chain around her neck for some strange reason???
Newer sccops can be reversed so that you can back into a pile of mulch/dirt/gravel/manure/peanut butter/miracle gel/etc. to load it up, then transport and dump. These kind will have 4 hitch pins instead of two to allow you to attach it to the tractor going forward or reverse. They look very similar to the older Dearborn scoop:
third party image
Enjoy your new toys..... ..Ed
'52 8N475798
coshman
03-14-2001 18:56:23
 Re: Re: 8N ATTACHMENTS in reply to Ed Gooding (VA), 03-14-2001 03:51:25
The 8N scoop I have is the small one, I do not know if it is reversable. If it is, I will be able to get more work out of it.
As you said, "it can be used to haul things, like fire wood etc.
Thanks for your response.
David
Dumb Logger
03-14-2001 17:25:06
Ed, did you tell your mother-in-law that some old Ford,s had a rumble seat? Did you get pictures? Your mother-in-law seems more trusting than mine.
Ed Gooding (VA)
03-15-2001 03:47:11
 Re: Re: Re: 8N ATTACHMENTS in reply to Dumb Logger, 03-14-2001 17:25:06
>> Your mother-in-law seems more trusting than mine. <<
Well, I have to confess that ever since the attempt to wrap the boom chain around her neck, she seems a little leery of me. I don't understand it. Do you think she's just paranoid???
LOL..... ...Ed
'52 8N475798
Dumb Logger
03-15-2001 16:33:26
 Re: Re: Re: Re: 8N ATTACHMENTS in reply to Ed Gooding (VA), 03-15-2001 03:47:11
It could have been the the rusty old chain, now if you had one of them new cad. plated chains in golden hues, she may have been more receptive.You know how women are about their looks. hth...grinnin' back at ya
JimNC
03-13-2001 18:00:19
coshman,
If the boom is well built it would handle that job. A N-engine is somewhere around 300#. The N lift will pick up around 500# to 800#. I would have to try it anyway. I took mine out with a cheap floor jack. I steadied the engine while the wife pulled it away from the trans. and let it down.
DAVID
03-14-2001 19:12:51
 Re: Re: 8N ATTACHMENTS in reply to JimNC, 03-13-2001 18:00:19
I hope to remove a 8N tractor engine with a 8N tractor with a 3-point boom attachment, load it on a trailer, take it to a machine shop and have the 8N engine rebuilt, (seleve kit, crankshaft redone, new bearings, valve job, gasket set etc.) and hope that everything turns out OK. Then restab the engine back into the tractor.
Sounds easy, but it might work.
David
denton
03-14-2001 07:29:24
My wife said she thought the N was "kinda cute" but smelled bad. I told her the same about all her candles in the house. If I can get her to pull an engine, I've graduated.
