New side braced Light Rated Boom Picture
Willy-N
11-21-2004 08:41:10
third party image
This is the new side braced Light Rated Boom. Mark H.
Bryan(OH)
11-21-2004 19:35:14
 Re: New side braced Light Rated Boom Picture in reply to Willy-N, 11-21-2004 08:41:10
Sorry to be ignorant but what do you use this for? Also, what part of the country is this?
Willy-N
11-21-2004 20:11:33
 Re: New side braced Light Rated Boom Picture in reply to Bryan(OH), 11-21-2004 19:35:14
It is a Combination Trailer Hitch for a regular Trailer and the Goose Neck type. Only used for moving them around on your farm. It also has a set of forks that slide in along with a Boom Pole all in one. You do not leave all those things in the hitch, only what you need to use. I live in Eastern Washington in what they call the "Desert Steppe Area" very dry most of the year. Mark H.
Fessman
11-21-2004 19:19:43
Mark,
Nice work. How do you draw the chains up tight??
Fessman
Willy-N
11-21-2004 20:07:17
 Re: New side braced Light Rated Boom Picture in reply to Fessman, 11-21-2004 19:19:43
There are 2- 7/16 grade 8 bolts with grade 8 washers. The head of the bolt goes thru the washer and chain then when you tigten up the nut it pulls the sholder into the steel till the threads bottom out. This way it is smooth steel holding it not the threaded section. This is not the method for my new one it is 2 X 1/4 inch angel iron instead of chain. Mark H.
Willy-N
11-21-2004 08:42:46
third party image
Ancoring point for bracing and boom. Mark H.
Dean
11-21-2004 14:24:03
 Re: New side braced Light Rated Boom Picture in reply to Willy-N, 11-21-2004 08:42:46
That is a nice piece of work. Looks real handy. I would buy one of those if such was available.
Dean
Willy-N
11-21-2004 15:12:13
 Re: New side braced Light Rated Boom Picture in reply to Dean, 11-21-2004 14:24:03
Soon as I get new materials and get back my plans back being checked for stress ratings. Mark H.
