2N stalls out on heavy pull
Tim Swarr
03-11-2001 04:55:19
I just purchased a 2N and everything seems great except that it wants to stall out on a heavy pull or in high grass with a bush hog. To bring the engine back to normal running speed when this happens, all I have to do is pull the choke out about one-quarter of an inch and she takes off and runs great again untill I hit another heavy pull. I think it is a carburation problem, but I thought I would ask some of you Ford N experts your opiions. If it is the carburator, should I rebuild or buy a new one? Thanks, Tim
ZANE
03-11-2001 05:31:03
 Re: 2N stalls out on heavy pull in reply to Tim Swarr, 03-11-2001 04:55:19
The first thing you should do is to turn the high speed mixture needle counter clockwise about a half turn and see if this improves the performance of the engine. Sometimes this is all that is needed.
If this doesn't help then the carburetor probably is in need of a good cleaning inside to remove built up foriegn material and or water.
Cleaning the N carburator.
If it is as cold as you say the problem may well be the presence of moisture in one or more places in the fuel system. Water likes to go to the bottom of gasoline and the bottom of the system is at the bottom of the carburator.You will never get it to run untill you get the carburator warm enough to melt the ice and get it out some way. The best thing to do is to take the carburator off and take it inside the shop and warm it up and then take it apart. Remove the big high speed jet needle from the front of the carb. It will be facing down and angled to the back slightly.
Be very cautious about the gas in a closed area and have no source of ignition so you don't set yourself of fire with the gas. The bottom of the bowl needs to be cleaned good and then blown out with compressed air. If you have the right tool to do it you need to remove the high speed fuel nozzle. That is the brass thing in the venturi (throat) of the intake that is pointing down and toward the front. It takes a long socket of the right size and don't try to get it out with a pair of pliers or you may get it so it can never be removed and cleaned. There will be several little holes in the jet that come into the bore from the sides and they all need to be opened with a needle of the right size. The best thing to use is a welders tip cleaner as it will have an assortment of different sizes and one will fit. Always use the biggest one you can get to go into the hole,
Be absolutely sure that the orifice in the bottom of the carburetor just below the point that the high speed needles sits when assembled is absolutely clean and free of all foreign material.
See the link below to find out how to have position control on the lift of your new tractor.
Snowplow
03-11-2001 07:23:29
 Re: Re: 2N stalls out on heavy pull in reply to ZANE, 03-11-2001 05:31:03
I agree that you probably need aricher fuel mix, which is why you choke is helping. I believe that the standard main adjustment setting is 2 1/2 turns out. Check that, then add as needed.
Steve IA
03-11-2001 05:17:26
If pulling the choke overcomes the problem, sounds like you have an air leak somewhere. Maybe around the carb shafts, the 2 halves of the carb, the intake manifold. Also the carb and filters may need a good cleaning and adjustment. I'd start with the screens, cleaning the carb and adjustment. Your F0-4 Manual will lead you through this. HTH. Steve 8N 169302
