Order Ford 8N Parts Online
8n Brake Drum Removal?
Dave In Iowa
03-09-2001 08:08:28
Sitting here at work, not working, but rather thinking about my 8N project. My IT manual is at home. So... After removing the rear wheels, I ASSuME that the brake drum is removed by removing the numerous slot-headed screws around the face of the drum. So how the $#*& do you get those screws out?!? I've broken the tips off of two large screwdrivers (squared shanked so you can use a wrench to turn them, and have come close to boogering up the screw heads. Any helpful hints?
As always, thanks for the help.
Al English
03-09-2001 19:28:36
 Re: 8n Brake Drum Removal? in reply to Dave In Iowa, 03-09-2001 08:08:28
Hi Dave, All the suggestions have been good, and the tool Brad mentioned will usually do the job, but here's another option. Put a good solid screwdriver in the screw(or even better, a blade that's missing the handle), give the end of the screwdriver a couple of good solid hits with a decent sized hammer. This will often loosen the screw enough for it to be removed. Good luck...Al English
Brad
03-09-2001 10:29:40
You need an impact driver. These come with screw driver tips that fit the 3/8 square drive on the tool. Stick the bit into the screw and whack the end with a big hammer. Auto parts stores carry them under the Lisle brand or you can chase down a Snap-On truck.
Eric PA
03-09-2001 10:26:34
I had the same trouble a couple of weeks ago until I dug a little deeper into this forum. I removed the four screws with ease by placing a screw driver on the outside edge of the screw and working it down with a hammer. I found it worked better with a smaller screw driver rather than with a real big one. i.e. the further away from the center of the screw you can get, the more leverage you will be able to achieve.
I too should be working rather than reading this forum ... I can't help it, I'm addicted.
good answer . . . Dell (WA)
03-09-2001 18:08:21
 Re: Re: Re: 8n Brake Drum Removal? in reply to Jim in Pensacola, , 03-09-2001 13:07:28
p/n 23667-S, 3/8-16 X 3/4 flathead screw.....Dell
