BIG WEEDS big Clumping noise
ccg9n
03-08-2001 18:35:11
WHEN I WENT TO USE THE PTO I GOT A CLUMPING NOISE NEAR THE TRANSMISSION. lOOKED IN THE BOOK AND THEN PULLED THE PTO SHAFT -then I drained the oil that was left. THE PTO SHAFT BEFORE THE SPLINES (near the engine) SHOWS WEAR. LOOKED IN THE BOOK AGAIN AND SEE THAT MAYBE ITS THE BEARING (715) ON THE TAKE-OFF UNIT. HOW HARD IS THIS TO TEARDOWN AND REPLACE??? DO I NEED TO SPLIT THE FRONT (ENGINE TO TRANNY OR JUST THE BACK TRANNY TO AXLE HOUSING??? HELP THE WEEDS ARE GROWING!! or...
can I ignore this and live with the clumping noise
John A (VA)
03-09-2001 16:48:41
 Re: BIG WEEDS big Clumping noise in reply to ccg9n, 03-08-2001 18:35:11
What you're hearing is the slack in the splines on the PTO shaft and the mating splines in the yokes in the hydraulic pump. My '48 makes the same noise whenever I have a heavy load on the lift, it's also much louder in the summer when the oil thins out from the heat. I've been told by several people much more learned than I to ignore it until it gets >real< loud, then replace the PTO shaft and the yokes in the hydraulic pump. Since this equates to a lot more $$$$ than I have in the tractor budget, I think I'll just ignore the noise for now... =)
Bill
03-09-2001 10:23:19
I have several big thumps every time the bush hog encounters a big tree. They go away after a while.
Bill Stanley
Larry 8N75381
03-09-2001 06:38:28
Are you sure it is not the hydraulic pump?
I have an 8N that will make a thumping noise when the lift is trying to lift a heavy load. It comes form the pump which is driven by the PTO shaft. The shaft could "carry" the noise forward so it sounds like it is nearer the tranny. Just a guess.
Larry
