Order Ford 8N Parts Online
8N gas tank vent
ken
03-06-2001 19:21:41
Removed gas tank from 8N, found a teat at 9:00 o'clock position on the raised dome, (from sitting on tractor, it is on left side of the dome on the tank).
Used a wire brush and found a very tiny hole. Does anyone know how big the hole should be, that is...about the size of a needle or size of a pencil lead. I will check later to see if the path is clear within the tank.
Thanks. ken
Claus
03-06-2001 21:16:47
 Re: 8N gas tank vent in reply to ken, 03-06-2001 19:21:41
Hole size is not critical. Just enough to let a little air into the tank while the fuel is being depleted. Obviously, one does not want the hole to be too large so kritters or debris can enter. Happy Motoring
Claus
