8-n can I jump 6 volt with 12 volt battery pack??
linky
03-05-2001 07:15:50
That's my question. Here we are in the middle of a beautiful snow storm and the kid won't start. Is it ok to use a battery-pack to jump a 6 volt battery??
Charlie in TX
03-05-2001 14:26:41
 Re: 8-n can I jump 6 volt with 12 volt battery pack?? in reply to linky, 03-05-2001 07:15:50
You can jump the 6v from 12v. Polarity is not important. Just don't let the vehicals touch. Put one side of the 12v system to the frame of the tractor, put the otherside to the strap that runs from the solinoid to the starter. You beter have the tractor in neutral or it will run you over.
bj/8N/mt
03-05-2001 07:37:19
direct answer to your question--yes; but
don't connect to the battery
assuming your tractor is still positive ground hook the positive to tractor ground and touch the negative to the post on the starter
DON'T FORGET TO PUT IT IN NEUTRAL as this defeats the interlock
also don't forget to turn key on
don't run starter more than ten seconds at a time and make sure it is in neutral so we don't read about you here
Jimp CO
03-05-2001 07:36:17
The answer is yes, BUT do not connect it to the 6V battery. Connect the NEG- clamp to the Starter NEG- post and the POS+ to a good ground. The key needs to be on and OUT OF GEAR.
There are several posts in the archives on this and Isuggest you read them. Look under jumping .
LOL
bj/8N/mt
03-05-2001 07:40:32
 Re: Re: 8-n can I jump 6 volt with 12 volt battery pack?? in reply to Jimp CO, 03-05-2001 07:36:17
looks like you and I were typing at the same time
Jimp CO
03-05-2001 07:50:20
 Re: Re: Re: 8-n can I jump 6 volt with 12 volt battery pack?? in reply to bj/8N/mt, 03-05-2001 07:40:32
at least we came up with the same answer.
He sounded like he was haveing a problem or was expecting one.
Later....
JImP
bj/8N/mt
03-05-2001 07:55:43
 Re: Re: Re: Re: 8-n can I jump 6 volt with 12 volt battery pack?? in reply to Jimp CO, 03-05-2001 07:50:20
If it were a high school government test we would both be up at the princpal's office trying to get them to believe we didn't cheat
