Identify an old plow
lonestarjeff
09-11-2004 17:24:38
If anybody's interested see if you can tell me about the plow I posted in the "Help Identify" gallery. I can't remember how to post it here.
Jeff
lonestarjeff
09-13-2004 19:50:32
 thanks everybody in reply to lonestarjeff, 09-11-2004 17:24:38
Just knowing what it is makes me feel better somehow. Thanks.
Jeff
Leroy
09-12-2004 07:12:43
 Re: Identify an old plow in reply to lonestarjeff, 09-11-2004 17:24:38
Is that beam cut off at the edge of the picture or is that a factory end? I can se no place for a coulter? Looks like a Ferguson mast and cross bar put on a beam from and old pull type plow. a few more pictures could identify it.
lonestarjeff
09-12-2004 09:24:50
 Here's another pic...maybe in reply to Leroy, 09-12-2004 07:12:43
third party image
Hope this works.
Jeb2N
09-12-2004 16:14:26
 Re: Here's another pic...maybe in reply to lonestarjeff, 09-12-2004 09:24:50
I agree; looks like a ferguson 3-point on an old JD horse-drawn plow frame. I didn't think about that until it was mentioned above. The fact that the plow frame starts to drop down at the front is very indicative of a horse-drown or very early trip plow and gives it away.
Jeb
lonestarjeff
09-12-2004 09:12:49
 Re: Identify an old plow in reply to Leroy, 09-12-2004 07:12:43
The end of the beam looks like it was cut off by a torch. It has a coulter w/ mounting bracket that was clamped to the beam(the bearings were broken ,so I removed it). Also, I removed a tail wheel assembly from the rear(it had "JD" cast in the mounting bracket).
Do you know if Ferguson made conversion kits for old pull-type plows?
I"ll try to post another pic.
Jeff
Leroy
09-13-2004 06:03:14
 Re: Identify an old plow in reply to lonestarjeff, 09-12-2004 09:12:49
Looks like I hit it, I thought it was a beam from some pull type plow, so from what you are saying it was from a J D no. 51 single bottom pull type or from the mounted plow for a L - LA or H John deere and as far as I know ferguson did not make a conversion kit but did sell the parts as repairs, years ago a neighbor did that with J D 2 bottoms for his Ferguson 40 tractors, you will need to replace that coulter and wheel for it to work corectly
DON TX
09-11-2004 19:54:39
third party image
See if this works.
http://www.tractorshed.com/gallery/identify/v8694.jpg
lonestarjeff
09-12-2004 00:09:55
 Re: Identify an old plow in reply to DON TX, 09-11-2004 19:54:39
Thanks Don, looks good. Any ideas on the plow?
Jeff
DON TX
09-12-2004 16:28:00
 Re: Identify an old plow in reply to lonestarjeff, 09-12-2004 00:09:55
Nope. Sorry.
DON TX
